Blue Oval Fanatics - Ford Forum
Go Back   Ford Forums & Technical Discussions > Ford Cars > Ford Mustang > 5.0L (1979-1995)
Reply
Thread Tools Search this Thread
Old 05-21-2015, 07:51 PM   #431
I Bleed Ford Blue
Moderator
I Bleed Ford Blue's Avatar
Fan#: 1121
What I Drive: 2017 Mustang GT convertible
I Bleed Ford Blue Outstanding Standing MemberI Bleed Ford Blue Outstanding Standing MemberI Bleed Ford Blue Outstanding Standing MemberI Bleed Ford Blue Outstanding Standing MemberI Bleed Ford Blue Outstanding Standing MemberI Bleed Ford Blue Outstanding Standing Member
Quote:
Originally Posted by white89gt View Post
Upon further review, the change actually took place in 96 rather than 99. Either way, it did change. If you look where the tie rod attaches, you will notice that the 94/95 knuckle in the background takes a jaunt upwards before going out, and the 98-04 goes straight out. This is the main difference I was referring to.
Interesting, I did not know they changed the steering geometry midstream during the sn-95 production.
If I were you, I would take some measurements on your car and use the knuckle that gets you closest to zero bump steer, and then throw on a bump steer eliminator kit to get it just right. You would be amazed at how well the car will handle if you just fix the few handling flaws that ford built into the car on purpose.
The other major flaw is the rear suspension setup, the factory four link tends to bind with stronger upper and lower arms with poly bushing. The upper triangulated arms are not meant to have stiff bushing in them, you need a certain amount of give or it will bind, that's why the factory bushing are rather soft. If you just ditch the quad shocks, upgrade the rear lower arms to stronger tubular ones with poly bushings, and get rid of the uppers and convert it to a torque arm system, and add either a watts link or a panhard bar, you will fix the problem and the car will handle like a third gen F body.
Back in 90 when I was out in San Diego there was I guy I knew who had an 87 GT who had it track prepped for SCCA and he did the torque arm conversion and fixed the bump steer. I got to drive it and the difference between his and mine was night and day. I had an 89 GT that was white with the lower in gray with a blue stripe on the beltline and gray interior.
__________________
17 Grabber Blue Mustang GT PP convertible 401A
17 Canyon Ridge Edge Titanium 302A
16 Ruby Red Edge SEL 201A
16 Blue Candy Focus Titanium 300A loaded
I Bleed Ford Blue is offline
Old 05-21-2015, 08:01 PM   #432
white89gt
Administrator Shane
white89gt's Avatar
Fan#: 1293
What I Drive: 1989 Mustang GT, 1997 F150
white89gt Outstanding Standing Memberwhite89gt Outstanding Standing Memberwhite89gt Outstanding Standing Memberwhite89gt Outstanding Standing Memberwhite89gt Outstanding Standing Memberwhite89gt Outstanding Standing Memberwhite89gt Outstanding Standing Member
I'll probably get this kit from Maximum Motorsports. It has tons of adjustment in it.
http://www.maximummotorsports.com/Bu...tyle-P448.aspx
I'll have to think on the rear end. I haven't put much thought into it. It actually hooks pretty decent, so I've never messed with it.
__________________
white89gt is offline
Old 05-22-2015, 12:15 PM   #433
white89gt
Administrator Shane
white89gt's Avatar
Fan#: 1293
I got these hoses today. Not real happy about their country of origin. These will likely get Ebay'd off. I want USA hoses.
__________________
Old 05-22-2015, 04:36 PM   #434
RangerSVT
Co-Founder
RangerSVT's Avatar
Fan#: 1269
What I Drive: V8 Fords
RangerSVT True FanaticRangerSVT True FanaticRangerSVT True FanaticRangerSVT True FanaticRangerSVT True FanaticRangerSVT True FanaticRangerSVT True FanaticRangerSVT True FanaticRangerSVT True FanaticRangerSVT True FanaticRangerSVT True Fanatic
Probably why they were on clearance, lol. At least you'll make some money off the chinese...
SVT
__________________
In-house Ranger Tech Expert
96 V8 4x4 Ranger on 47's
02 V8 4x4 Sport Trac on 32's
Y2K F150 4x4 Lariat
RangerSVT is offline
Old 05-23-2015, 04:24 PM   #435
white89gt
Administrator Shane
white89gt's Avatar
Fan#: 1293
^^^ This task of finding USA hoses may prove to be more difficult than I had anticipated. So far no luck.
__________________
Old 05-27-2017, 09:02 PM   #436
white89gt
Administrator Shane
white89gt's Avatar
Fan#: 1293
I gave her a little shake down today. Can't wait to get it registered!
Rev it up! 89 edition - YouTube
+ YouTube Video
ERROR: If you can see this, then YouTube is down or you don't have Flash installed.
__________________
Old 10-23-2017, 08:47 AM   #437
white89gt
Administrator Shane
white89gt's Avatar
Fan#: 1293
Got the Stang out for a little gallop through the canyon on Saturday. She loves to get out and run.....
__________________
Old 11-01-2017, 08:35 PM   #438
autolite
Senior Pilot
autolite's Avatar
Fan#: 1468
What I Drive: 1998 Black Mustang GT
autolite Excellent Standing Memberautolite Excellent Standing Member
nice pictures as always.
__________________
98 Mustang GT
14 F150 XLT
10 Escape Limited,
06 Harley Ultra Classic
2008 Focus SE
autolite is offline
Old 11-04-2017, 08:12 PM   #439
white89gt
Administrator Shane
white89gt's Avatar
Fan#: 1293
Thank you my friend!
__________________
Old 02-26-2018, 08:41 AM   #440
white89gt
Administrator Shane
white89gt's Avatar
Fan#: 1293
A project almost 4 years in the making is coming to a head. All things are either here or on the way to convert to 5 lug. Just need to get friction modifier and gear oil, and get the tires mounted. Can't believe it's been this long, but.... once this snow is gone, it is go time.
__________________
Reply
Bookmarks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright © VerticalScope Inc. All rights reserved. : Terms of Use : Copyright : Privacy Policy : Advertise Information
Blue Oval Fanatics - Online Ford Community for the UK, North & South America, Europe, Asia, Australia, and Africa regions. We are the Internet's Newest Ford Forum. As our site continues to grow, we'll be offering a large collection of Ford related news, articles and club events information. We also offer a free Ford classifieds, gallery, social groups and events information. Our goal is to be the premier information outlet for Ford owners. If you own other makes have a look at Challenger Hellcat Forum, Charger Hellcat Forum, Cadillac ATS-V Forum, Cadillac CTS-V Forum, Lexus RC-F Forum, Lexus GS-F Forum, Mercedes GLA Forum, Mercedes GLE Forum and Volvo XC90 Forum.
