Blue Oval Fanatics - Ford Forum
Go Back   Ford Forums & Technical Discussions > Ford Cars > Ford Mustang > 5.0L (1979-1995)
Reply
Thread Tools Search this Thread
Unread 11-14-2012, 09:08 AM   #1
white89gt
Administrator Shane
white89gt's Avatar
Fan#: 1293
What I Drive: 1989 Mustang GT, 1997 F150
white89gt Outstanding Standing Memberwhite89gt Outstanding Standing Memberwhite89gt Outstanding Standing Memberwhite89gt Outstanding Standing Memberwhite89gt Outstanding Standing Memberwhite89gt Outstanding Standing Memberwhite89gt Outstanding Standing Member
GT40P Swap Information
I would like to get a thread started on GT40P (aka P heads) head swap information, and what works. The P heads offer a great junk yard upgrade to your 5.0 Mustang. They were offered on 5.0 Explorers and Mountaineers starting during the 97 production year, and continued through 2001 when the 5.0 was discontinued. The P heads have a unique spark plug angle, unlike any other head. This limits your options for headers, but many people have found ways to get around it. As a side note, Ford Racing and MAC offer P-specific headers, but they are costly in comparison to other headers.
When I started my swap, I knew that I may be getting new headers to complete the swap. I had some old school MAC headers with the 4 piece flange - which I hate because you have to get a pry bar to get the holes to line up. So, I was OK with getting a different set of headers. BUT, they fit. I was able to use them by getting a shorty plug for cylinder 7. This bothered me, and I started looking for an alternative. I found a Brentech (Brothers Performance house brand) header on sale at Christmas 2 years ago for $109.00 - BINGO. I looked at the design, and could tell by sight that cylinder 7 provided more room.
NEW INFO! - Here are some flow numbers between the heads: http://www.carbdford.com/tech/flowdata.htm
Look at the difference in the room on cylinder 7 (2nd from right).
Here is cylinder 7 now:
You may see that my plug wires are not your usual 135 degree boot that the factory plug wires come with. I went to a 90 degree boot for some added clearance. The plug wires I used are for an 89 Chevy Blazer with a 350. They turned out great.
This is the passenger side. I had zero issues over here with either header. You can see there is plenty of clearance here.
OK, next issue. The P heads do not have the smog holes on the back like the factory E7TE heads. So, the tube that goes on the back side of the head is worthless. Don't fear if you have to pass the sniffer. Mine passed better with these heads. So now you will have the valve that redirects the smog pump to the back of the heads with no place to go. What I did was simply put a "T" in here that I had laying around.
If you look, the cap says "Antifreeze Coolant" on it.
Feel free to add anything you have found, and I will post more in the future on the intake, 65mm throttle body, and injectors that can be harvested from the Explorer and Mountaineer.
BTW.... All of the white dust all over under the hood was because I had just got it home after being painted.
__________________
white89gt is offline
Unread 11-17-2012, 07:55 AM   #2
white89gt
Administrator Shane
white89gt's Avatar
Fan#: 1293
Next up, I'd like to talk about the throttle body. The Explorer with the 5.0 has a 65mm throttle body. The factory Mustang throttle body is anywhere between 58mm and 60mm - mine measured at 59mm. The Explorer throttle body can be made to work using some parts from your factory Mustang throttle body. Here are a couple of great "how-to's" on how to make the Explorer throttle body a usable piece. It is rather simple. I would like to note that I tack welded my bellcrank on, and it has worked fine. I also did not have to change breather tube directions, and my TP sensor went right on with no mods.
http://oldfuelinjection.com/files/Ex...lebody_fix.pdf
http://www.veryuseful.com/mustang/te...orer65mmTB.pdf
Just one more thing I'd like to mention - I got my throttle body for 25 dollars, and it had the intake elbow, EGR, and TP sensor attached to it. I was able to sell the EGR vavle and TP sensor, and I literally made a 15 dollar profit.
Here is a picture of the Explorer throttle body on my Mustang. Please excuse the dust. This is right after it was painted, so it has paint dust on it.
Unread 11-17-2012, 10:34 AM   #3
white89gt
Administrator Shane
white89gt's Avatar
Fan#: 1293
The next thing you can harvest from an Explorer is the intake manifold. It is a HUGE upgrade over the factory Mustang intake manifold. It has flow numbers that are comparable to the GT40 or Cobra intake manifold. In fact, the bottom manifold is almost identical.
Here are some HP numbers comparing the GT40, Cobra, and Explorer intake manifolds. These figures were done by Super Ford Magazine:
The Explorer lower intake does not have a boss for the ACT sensor. You have two options. Either you can drill and tap the Explorer intake, or you can relocate it to the intake tube prior to the throttle body. This is where Ford moved it starting in 1994 on the Mustang. This is also what I did.
Here is a REALLY good write up on a swap to an Explorer intake:
http://www.allfordmustangs.com/Detailed/614.shtml
Unread 11-19-2012, 03:46 PM   #4
white89gt
Administrator Shane
white89gt's Avatar
Fan#: 1293
I thought I would put some GT40P head identifiers up so you can easily spot them in a wrecking yard. The P heads have "GT40P" in the casting in the valley near the rocker arms. That may not be easy to spot if the valve covers are still on them. There are also 4 bars on each end - and that may not be easy to spot if the accessories are still intact. My personal favorite identifier is "GTP" in the casting near the bottom right head bolt. There is a "P" directly above it that can only be partially seen with the valve covers on as well.
I gathered some photos (I like pics) via google and put this together below:
Unread 11-19-2012, 04:53 PM   #5
RangerSVT
Co-Founder
RangerSVT's Avatar
Fan#: 1269
What I Drive: V8 Fords
RangerSVT True FanaticRangerSVT True FanaticRangerSVT True FanaticRangerSVT True FanaticRangerSVT True FanaticRangerSVT True FanaticRangerSVT True FanaticRangerSVT True FanaticRangerSVT True FanaticRangerSVT True FanaticRangerSVT True Fanatic
Great info
SVT
__________________
In-house Ranger Tech Expert
96 V8 4x4 Ranger on 47's
02 V8 4x4 Sport Trac on 32's
Y2K F150 4x4 Lariat
RangerSVT is offline
Unread 11-26-2012, 06:14 PM   #6
white89gt
Administrator Shane
white89gt's Avatar
Fan#: 1293
If you are having issues with header/plug clearance, you can also use an Accel shorty/header plug. It can gain you some additional space to keep your plug wire boots from melting. The part number is P526S. It is a double platinum plug.
Unread 11-26-2012, 06:15 PM   #7
white89gt
Administrator Shane
white89gt's Avatar
Fan#: 1293
Quote:
Originally Posted by RangerSVT View Post
Great info
SVT
Thank you Rick!
Unread 01-03-2013, 06:05 PM   #8
white89gt
Administrator Shane
white89gt's Avatar
Fan#: 1293
A good friend of mine just completed a GT40P and Explorer intake swap on his Mustang. Here's a picture of the completed project.
One thing I found interesting with his swap is, with the BBK headers he had issues with cylinder 4 clearance. My headers are made by Brentech and my only plug that was close was cylinder 7 (see above). The Brentech headers are made in the exact same building that the BBK headers are made (BBK and Brothers Performance are next door to each other).
He also eliminated the A/C and smog pump while doing his swap. I have only eliminated my A/C lines and the drier (I think that's what it's called) that mounts to the firewall. He also added the electric fan. All of that ought to free up some horsepower.
Unread 01-03-2013, 06:12 PM   #9
RangerSVT
Co-Founder
RangerSVT's Avatar
Fan#: 1269
Remove the AC eliminator pulley, and the smog pump and short-belt it. Even though you removed the AC, the eliminator pulley is still a parasitic drag...
SVT
__________________
Y2K F150 4x4 Lariat
Unread 01-03-2013, 06:14 PM   #10
RangerSVT
Co-Founder
RangerSVT's Avatar
Fan#: 1269
Shane, do you have a certain place you purchase the U groove plugs? The place I checked were $9 per plug....
SVT
__________________
Y2K F150 4x4 Lariat
Reply
Bookmarks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright © VerticalScope Inc. All rights reserved. : Terms of Use : Copyright : Privacy Policy : Advertise Information
Blue Oval Fanatics - Online Ford Community for the UK, North & South America, Europe, Asia, Australia, and Africa regions. We are the Internet's Newest Ford Forum. As our site continues to grow, we'll be offering a large collection of Ford related news, articles and club events information. We also offer a free Ford classifieds, gallery, social groups and events information. Our goal is to be the premier information outlet for Ford owners. If you own other makes have a look at Challenger Hellcat Forum, Charger Hellcat Forum, Cadillac ATS-V Forum, Cadillac CTS-V Forum, Lexus RC-F Forum, Lexus GS-F Forum, Mercedes GLA Forum, Mercedes GLE Forum and Volvo XC90 Forum.
